[{"id":"41134bba.4413c4","type":"tab","label":"Type 80","disabled":true,"info":""},{"id":"d5b095c1.84afe8","type":"ncd-wireless-node","z":"41134bba.4413c4","name":"Vibration Sensor ","connection":"802b9322.5d98","config_comm":"802b9322.5d98","addr":"00:13:a2:00:41:df:2a:76","sensor_type":"80","auto_config":true,"node_id_delay_active":true,"node_id":"0","delay":"0","destination":"0000FFFF","power_active":false,"power":"4","retries_active":false,"retries":10,"pan_id":"7FFF","change_enabled":"","change_pr":"0","change_interval":"0","cm_calibration":"60.6","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","impact_accel":"0","impact_data_rate":"4","impact_threshold":25,"impact_duration":1,"activ_interr_x":1,"activ_interr_y":2,"activ_interr_z":4,"activ_interr_op":8,"force_calibration_co2_auto_config":"","force_calibration_co2":400,"filtering":0,"data_rate":5,"time_series":0,"reading_type":1,"mode_80_active":true,"mode_80":"1","filter_80_active":false,"output_data_rate_101_active":true,"output_data_rate_101":"9","sampling_duration_101_active":true,"sampling_duration_101":"40","sampling_interval_101_active":false,"sampling_interval_101":"0","full_scale_range_101_active":"","full_scale_range_101":1,"x_axis_101":false,"y_axis_101":"","z_axis_101":"","x":420,"y":380,"wires":[["b5d7c7fb.40d898","d681cf0c.71587"]]},{"id":"9d1c2e79.a723c","type":"debug","z":"41134bba.4413c4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":260,"wires":[]},{"id":"b5d7c7fb.40d898","type":"split","z":"41134bba.4413c4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":780,"y":500,"wires":[["32553036.0b46c"]]},{"id":"32553036.0b46c","type":"switch","z":"41134bba.4413c4","name":"1 Vibration Plus","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"odr","vt":"str"},{"t":"eq","v":"temperature","vt":"str"},{"t":"eq","v":"x_rms_ACC_G","vt":"str"},{"t":"eq","v":"x_max_ACC_G","vt":"str"},{"t":"eq","v":"x_velocity_mm_sec","vt":"str"},{"t":"eq","v":"x_displacement_mm","vt":"str"},{"t":"eq","v":"x_peak_one_Hz","vt":"str"},{"t":"eq","v":"x_peak_two_Hz","vt":"str"},{"t":"eq","v":"x_peak_three_Hz","vt":"str"},{"t":"eq","v":"y_rms_ACC_G","vt":"str"},{"t":"eq","v":"y_max_ACC_G","vt":"str"},{"t":"eq","v":"y_velocity_mm_sec","vt":"str"},{"t":"eq","v":"y_displacement_mm","vt":"str"},{"t":"eq","v":"y_peak_one_Hz","vt":"str"},{"t":"eq","v":"y_peak_two_Hz","vt":"str"},{"t":"eq","v":"y_peak_three_Hz","vt":"str"},{"t":"eq","v":"z_rms_ACC_G","vt":"str"},{"t":"eq","v":"z_max_ACC_G","vt":"str"},{"t":"eq","v":"z_velocity_mm_sec","vt":"str"},{"t":"eq","v":"z_displacement_mm","vt":"str"},{"t":"eq","v":"z_peak_one_Hz","vt":"str"},{"t":"eq","v":"z_peak_two_Hz","vt":"str"},{"t":"eq","v":"z_peak_three_Hz","vt":"str"}],"checkall":"true","repair":false,"outputs":23,"x":1050,"y":520,"wires":[["3c156e5f.554db2"],["23ad8749.3ab908"],["c152d3a1.93858"],["637bc903.a65d78"],["676d198b.213728"],["f7fce9e7.dc7a08"],["a10b4a63.94d9a8"],["f4449d45.71e68"],["3c64e6d3.19d1ea"],["1bbfafa8.23a0a"],["f73ae3a1.cc379"],["9df25280.9e4fc"],["9c93147e.1fd5c8"],["8f0cab1d.4cce38"],["c868d9b8.267598"],["f4b0291.4f5c6d8"],["43c1490a.822228"],["b217d5fd.895888"],["1020dbc4.dc5f04"],["40650bc5.6444b4"],["c9f03f33.a19dc"],["6dcaa7c9.51e4d8"],["7e9771b5.dcdf2"]]},{"id":"23ad8749.3ab908","type":"ui_chart","z":"41134bba.4413c4","name":"","group":"d4b2549d.45a038","order":2,"width":0,"height":0,"label":"Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"-50","ymax":"125","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1400,"y":400,"wires":[[]]},{"id":"c152d3a1.93858","type":"ui_chart","z":"41134bba.4413c4","name":"","group":"d4b2549d.45a038","order":3,"width":0,"height":0,"label":"x_rms_ACC_mg","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"0","ymax":"64","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1420,"y":460,"wires":[[]]},{"id":"637bc903.a65d78","type":"ui_chart","z":"41134bba.4413c4","name":"","group":"d4b2549d.45a038","order":4,"width":0,"height":0,"label":"x_max_ACC_mg","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"0","ymax":"64","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"c
This file has been truncated. show original
