I had previously had a working solution for my ProXR relay board (the 24-relay version), and it responded as expected in all cases. It has since developed a strange quirk. When I send a read request (via the API) I get the ‘command success’ message, instead of an array of state bytes. I can still set the relay states by directly commanding a specific relay or by sending a state byte to an entire bank, but the read request gets no state info. I’m certain this worked before, and I don’t think anything changed to cause this. I do turn relay refresh off briefly to set all relays to their default states, but then turn it back on again.
To be clear, these are the bytes sent/received:
• open relay #5 in bank #1 (xFE x70 x01)
• close relay #5, bank #1 (xFE x68 x01)
• open relay #5 while closing the others in bank #1 (xFE x8C x05 x01)
• query state of bank #1 (xFE x7C x01)
• query all banks (xFE x7C x00)
• the response I get in ALL cases (x01 x55)
How would I go about troubleshooting this issue?
