This is a follow on from previous post WiFi & XBee antennas
I’d like to confirm that this is the correct combination of devices & ask some questions. First project 4 RTUs, later projects more.
PR60-1_R85PL: Relay Controller 8-Channel General Purpose SPDT + 8 Channel ADC ProXR Lite
Pluggable connectors, 5 amp SPDT -
XBP9B-DMST-002: 900MHz (North America) Long-Range Wireless Mesh XBee-Pro® Communications Module
an outdoor antenna for 900MHZ such as:
Antenna 900 MHz Omnidirectional 3dBi w/ N-f. Optional bracket mount
and adapter to SMA connector on the XBee comm modules
We will convert 24VAC (HVAC standard) to 12VDC for the ProXR. We have used this before, rated at 1.5A, sufficent for our use, drive 5 relays on your board even at max 60ma/relay:
MODEM:
We see this modem listed on the page for the PR60-1_R85PL
- 900HP-S3B Long Range Wireless Mesh Modem with USB Interface
- we don’t understand the difference of these:
** Standard compatible with NCD Industrial Devices
** API compatible with IoT Long Range Wireless
- it seems these are applicable to that USB modem. Is that correct?
- We would much prefer a hard-wire ethernet modem connection to our controller for multiple reasons (not WiFi to our controller). E.g. we address the modem as an IP device, sockets or HTTP. Is this one compatible with the board?
- PR55-17B: Industrial IoT Wireless to Ethernet Modem
- We see this page for using it with Comm Operator. We assume that we can poll the devices (we prefer to poll, not have the device broadcast at intervals, since it is continuously powered): Receiving Wireless Sensor Data over Ethernet - NCD.io
- When we poll, are the send/response packets the same binary payload as the above document?
- Note: we do not want to use node-red and introduce yet another layer of communication - and potential point of failure
Thank you for you clarifications and help.
