We are trying to figure out why our 1-Channel Production Counter (https://store.ncd.io/product/iot-long-range-wireless-production-counter-transmitter/) is not counting pulses from a water meter that outputs a signal from a reed switch. The water meter has 2 wires (+ and -) which we have connected to the water meter.
We have successfully used this sensor with other water meters in the past.
We have adjusted the pulse width to be 500 msec (up from 100 or so), and still can’t seem to get it to work.
Also, FYI, I believe your documentation for this product is incorrect; on the product page you say the following:
M12 Pin Pin Info
1 Input -ve ( connect to Ground) ( Brown)
2 Not Connected (White)
3 Input +ve ( connect to Signal) ( Blue)
4 DC power In +ve ( Black)
5 DC power In -ve (Gnd) (Gray)
However, from our previous setups and testing, the correct wires are BLUE (+) and WHITE (-) and not BLUE(+) and BROWN (-) like stated. Can you confirm this is an error, or are we missing something?
Anyways, we are looking to get a bit more info on the signal being generated by the water meter, but was wondering if you had any ideas for now? Would we need a pull up or down resistor?
Thank you!
