Hello everyone!
We are testing new possibilities of device integration, and we have in mind to communicate your wireless devices with a Raspberry using a USB-Modem.
The problem is that when installing the library, it gives me the following error:
lord@raspberrypi:~ $ npm install ncd-red-wireless
npm ERR! code 1
npm ERR! path /home/lord/node_modules/ncd-red-wireless/node_modules/@serialport/ bindings
npm ERR! command failed
npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || no de-gyp rebuild
npm ERR! make: se entra en el directorio ‘/home/lord/node_modules/ncd-red-wirele ss/node_modules/@serialport/bindings/build’
npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.o
npm ERR! make: se sale del directorio ‘/home/lord/node_modules/ncd-red-wireless/ node_modules/@serialport/bindings/build’
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.0.0
npm ERR! gyp info using node@16.16.0 | linux | arm
npm ERR! gyp info find Python using Python version 3.9.2 found at “/usr/bin/pyth on3”
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args ‘/usr/lib/node_modules/npm/node_modules/node-gyp/ gyp/gyp_main.py’,
npm ERR! gyp info spawn args ‘binding.gyp’,
npm ERR! gyp info spawn args ‘-f’,
npm ERR! gyp info spawn args ‘make’,
npm ERR! gyp info spawn args ‘-I’,
npm ERR! gyp info spawn args ‘/home/lord/node_modules/ncd-red-wireless/node_mo dules/@serialport/bindings/build/config.gypi’,
npm ERR! gyp info spawn args ‘/usr/lib/node_modules/npm/node_modules/node-gyp/ addon.gypi’,
npm ERR! gyp info spawn args ‘/home/lord/.cache/node-gyp/16.16.0/include/node/ common.gypi’,
npm ERR! gyp info spawn args ‘-Dlibrary=shared_library’,
npm ERR! gyp info spawn args ‘-Dvisibility=default’,
npm ERR! gyp info spawn args ‘-Dnode_root_dir=/home/lord/.cache/node-gyp/16.16 .0’,
npm ERR! gyp info spawn args ‘-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_mo dules/node-gyp’,
npm ERR! gyp info spawn args ‘-Dnode_lib_file=/home/lord/.cache/node-gyp/16.16 .0/<(target_arch)/node.lib’,
npm ERR! gyp info spawn args ‘-Dmodule_root_dir=/home/lord/node_modules/ncd-re d-wireless/node_modules/@serialport/bindings’,
npm ERR! gyp info spawn args ‘-Dnode_engine=v8’,
npm ERR! gyp info spawn args ‘–depth=.’,
npm ERR! gyp info spawn args ‘–no-parallel’,
npm ERR! gyp info spawn args ‘–generator-output’,
npm ERR! gyp info spawn args ‘build’,
npm ERR! gyp info spawn args ‘-Goutput_dir=.’
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Na n::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:78:51: warning: cast between incompatible functio n types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_wo rk_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_wor k_cb)EIO_AfterOpen);
npm ERR! | ^~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update( Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:135:53: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_w ork_cb)EIO_AfterUpdate);
npm ERR! | ^~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(N an::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:175:52: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_wo rk_cb)EIO_AfterClose);
npm ERR! | ^~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(N an::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:215:52: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_wo rk_cb)EIO_AfterFlush);
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan ::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:270:50: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 270 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work _cb)EIO_AfterSet);
npm ERR! | ^~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan ::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:314:50: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 314 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work _cb)EIO_AfterGet);
npm ERR! …/src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
npm ERR! …/src/serialport.cpp:329:96: error: no matching function for call to ‘ v8::Object::Set(v8::Localv8::String, Nan::FactoryBasev8::Boolean::retur n_t)’
npm ERR! 329 | results->Set(Nan::Newv8::String(“cts”).ToLocalChecked(), Nan::Newv8::Boolean(data->cts));
npm ERR! | ^
npm ERR! In file included from /home/lord/.cache/node-gyp/16.16.0/include/node/n ode.h:63,
npm ERR! from …/…/…/…/…/nan/nan.h:60,
npm ERR! from …/src/./serialport.h:6,
npm ERR! from …/src/serialport.cpp:1:
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/v8.h:3961:37: note: can didate: ‘v8::Maybe v8::Object::Set(v8::Localv8::Context, v8::Local<v8::V alue>, v8::Localv8::Value)’
npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,
npm ERR! | ^~~
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/v8.h:3961:37: note: c andidate expects 3 arguments, 2 provided
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/v8.h:3964:37: note: can didate: ‘v8::Maybe v8::Object::Set(v8::Localv8::Context, uint32_t, v8::L ocalv8::Value)’
npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,
npm ERR! | ^~~
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/v8.h:3964:37: note: c andidate expects 3 arguments, 2 provided
npm ERR! …/src/serialport.cpp:330:96: error: no matching function for call to ‘ v8::Object::Set(v8::Localv8::String, Nan::FactoryBasev8::Boolean::retur n_t)’
npm ERR! 330 | results->Set(Nan::Newv8::String(“dsr”).ToLocalChecked(), Nan::Newv8::Boolean(data->dsr));
npm ERR! | ^
npm ERR! | ^~~
npm ERR! | ^~~
npm ERR! …/src/serialport.cpp:331:96: error: no matching function for call to ‘ v8::Object::Set(v8::Localv8::String, Nan::FactoryBasev8::Boolean::retur n_t)’
npm ERR! 331 | results->Set(Nan::Newv8::String(“dcd”).ToLocalChecked(), Nan::Newv8::Boolean(data->dcd));
npm ERR! | ^
npm ERR! | ^~~
npm ERR! | ^~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaud Rate(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:363:58: warning: cast between incompatible functi on types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 363 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_af ter_work_cb)EIO_AfterGetBaudRate);
npm ERR! | ^~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! …/src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t )’:
npm ERR! …/src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Localv8::String, Nan::IntegerFactoryv8::Integer::r eturn_t)’
npm ERR! 378 | results->Set(Nan::Newv8::String(“baudRate”).ToLocalChecke d(), Nan::Newv8::Integer(data->baudRate));
npm ERR! | ^
npm ERR! | ^~~
npm ERR! | ^~~
npm ERR! …/src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(N an::NAN_METHOD_ARGS_TYPE)’:
npm ERR! …/src/serialport.cpp:409:52: warning: cast between incompatible functi on types from ‘void ()(uv_work_t*)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_w ork_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
npm ERR! 409 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_wo rk_cb)EIO_AfterDrain);
npm ERR! …/src/serialport.cpp: At global scope:
npm ERR! …/src/serialport.cpp:430:28: warning: unnecessary parentheses in decla ration of ‘ToParityEnum’ [-Wparentheses]
npm ERR! 430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::St ring>& v8str)) {
npm ERR! | ^
npm ERR! …/src/serialport.cpp:449:30: warning: unnecessary parentheses in decla ration of ‘ToStopBitEnum’ [-Wparentheses]
npm ERR! 449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
npm ERR! | ^
npm ERR! In file included from …/…/…/…/…/nan/nan.h:60,
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/node.h:847:7: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNC TION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_registe r_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-W cast-function-type]
npm ERR! 847 | (node::addon_register_func) (regfunc),
npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! /home/lord/.cache/node-gyp/16.16.0/include/node/node.h:881:3: note: in expansion of macro ‘NODE_MODULE_X’
npm ERR! 881 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readabil ity/null_usage)
npm ERR! …/src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
npm ERR! 483 | NODE_MODULE(serialport, init);
npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/seri alport.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error:makefailed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/no de_modules/node-gyp/lib/build.js:194:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:527:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:interna l/child_process:291:12)
npm ERR! gyp ERR! System Linux 5.15.32-v7l+
npm ERR! gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_module s/node-gyp/bin/node-gyp.js” “rebuild”
npm ERR! gyp ERR! cwd /home/lord/node_modules/ncd-red-wireless/node_modules/@ser ialport/bindings
npm ERR! gyp ERR! node -v v16.16.0
npm ERR! gyp ERR! node-gyp -v v9.0.0
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! /home/lord/.npm/_logs/2022-08-02T14_15_24_067Z-debug-0.log
I can install the other libraries, such as ncd-red-mcp23008, but with the ncd-red-wireless I have problems.
If you could help me or know what could be wrong, I would appreciate it!
Thanks.
Greetings.
