The sensor is the only thing I put in cfg mode. After I hit deploy and waited some time, I would hit reset to take it out of cfg. At some point I would see the cfg acknowledged message, but the setting did not change in the sensor.
We have a video here that demonstrates changing sensor settings through Node-Red:
You need to make changes to the sensor node’s settings, deploy, then put Node-Red into config mode, then put the sensor in config mode. The video demonstrates this but if you have any questions please let me know.
Excellent, I’ve got it now.
One question on the ODR parameters. To confirm, if I’m looking for 58Hz, 63Hz, and 86Hz, is that a setting of 400, based on the info Bhasker posted: “400sps (Range 6.25 – 100 Hz) 0x09”? He had recommended 200, but it seems like that would be below the range as I read it " 200sps (Range 3.125 – 50 Hz)".
Thanks.
400 will be ideal. Also set range to 2g
Thanks for all the help!
