Pro XR 16 channel relay board
We are having issues with out Pro XR relay board. We are trying to connect to it using a script in python and only had luck connecting to it with NCD base. After a few failed attempts, we changed the baud rate of the Board to 9600 and now we aren’t even able to connect to it using the NCD Base anymore.
We have another board and RS 485 module that we are testing with as well which worked well with the code, so we were able to eliminate that. We also mix and matched the RS 485 module to the working board and the working 485 module to the troublesome board, both results turned up nothing.
I see documentation for resetting the Serial module to factory settings, but is there anyway to do that with the boards? If so, how would we go about it. Thank you
Can you please provide photos of your boards? I am wondering if they are the new Black ProXR boards or the older green versions.
Thank you for the reply. They are the newer black boards.
Just bumping the thread for visibility. If this is a critical failure, how would we go about returning them?
