The " Industrial Wireless Absolute & Gauge Pressure Sensor", SKU: PR52-33P appears to come with a 0 - 1000 psi transducer. I need to measure 0 - 3000 psi. Can I order with this transducer range?
Yes, this product has been updated to accommodate a 5,000psi option (we have the sensor element in stock) and is available here, total manufacturing time is up to 5 business days:
That is good news.
Where would I find a list of pressure range options available to order?
When adding this item to your shopping cart, you can choose the range options, ranges are listed in a drop down menu.
Let me know if you need anything.
The only options in the Max Pressure Range dropdown are:
- Absolute Pressure 0 - 100 psi
- Gauge Pressure 0 - 500 psi
- Sealed Gauge Pressure 0 - 1000 psi
The page I’m looking at is …
https://store.ncd.io/product/industrial-wireless-absolute-gauge-pressure-sensor-with-1-4-npt/
If I’m on the wrong page, please redirect me.
You will probably need to reload the page, I just verified the description and the product options have all been updated with 0-5000 in the “Max Pressure Range” setting. Please try again.
