PR60-21 with PR55-22
I have the PR55-22 WiFi Communications module installed onto the PR60-21 Digital Pot board and I have not been able to properly communicate to the PR60-21. I have connected using the USB connection and it fails to identify any modules. I have connected using WiFi with the same results. When using the USB with Base Station, Baudrate set to 115200 the response is the the controller did not respond to the Baud Rate. Sometimes the Base station Software V4.0.8 does load but does not identify any device.
  1. Where can I find information for the R and C buttons on the PR55-22?
  2. There is a Run Program switch on the PR60-21 board, where can I find information about how to program this board? The only link I have found for the Digital Pot board is an RS-232 interface and is nothing like the board I have.
