I am using a PR55-4A Current Monitor to gather AC current load information. The value being returned by the current monitor is approximately 6 amps less than what a Fluke meter is registering.
I see there is a calibration field for the sensor. Is there a recommended calibration procedure to help to determine the proper value for this field?
We don’t have a 3rd meter at this point to double check but the meter we used was brand new and we assumed it was calibrated at the factory.
Asset is always on.
Asset is an industrial air compressor.
I setup a laptop next to the air compressor so I can see the data packet from the Current Monitor and also see the Fluke meter to be able to get as simultaneous a reading as possible.
