PR55-45L - Shorter probe cable available?
Hello all, was wondering if a shorter probe cable was available? I’ve done some looking around for m12 five pin cables but cannot seem to find anything that’s short ( less than a foot). I’d like to try to clean up the presentation of the devices were using for ambient temp/humidity/air quality monitoring.
yes we can build those, how many do you need ?
Hey Bhaskar, apologies for the late reply. Thank you for letting me know that these exist. I will be slating the project for after the New Year and can reach back out with an estimated amount to receive a quote.
Hello Bhaskar, @Bhaskar this topic has came back into question for a new build. How short can the cables possibly be? is it necessary to have even any cable between the connection point and the diffuser? Ideally, it’s as minimal as possible to clean up the presentation. How would I go about placing an order for these? I am looking at around maybe 40 of the probes. Also, can you let me know what the metal is made out of? I need to verify if the probe housing is a material allowed in a sterile facility.
Yes we can build without cables(just long enough to connect m1/ connectors with sensor)
Or we can put the sensor inside the box and put an air vent.
Thanks for the quick reply. I think the best solution would be to use new manufactured probes w/o the cable rather than replacing our existing sensors as we have physically and systemically deployed most of them to meet our target launch date. Can you let me know how to go about the ordering process for these? I can send you a PM and let you know what company I am from if that will help.
this link can be used to place an online order
