Hello, we have previously used the PR55-17A modem to configure the baud rate and Pan ID of the PR55-34 devices using the NCD io Xbee to RS 485 converter utility.
However, with this latest set of PR55-34, the modem will not recognize the new PR55-34 on the same default pan ID. I’m able to connect to the older smaller PR55-34 with no issues still using the same methods.
I noticed now with the new larger PR55-34 units, Alpha Station does recognize them(will not recognize the old ones that work with NCD io Xbee to RS 485 converter utility). However, I cannot seem to get the PR55-34 units into configuration mode. Upon being prompted to by alpha station, nothing ever changes after pressing the R button and holding the C button for 6 seconds. I noticed, no LED comes on when pressing the C button, like in the video. The view and setup buttons for the device are greyed out in my alpha station unlike in the video.
This is the first time I’ve gotten Alpha station see a remote device.
Do you have any suggestions for configuring the PR55-34, I would like to change the RS-485 Baud Rate and the Pan ID.
