Pr55-26c - node red issue
Hello
Sorry i have a question about this sensor.
Currently the sensor is connected to nodered but i don´t have any measure in node red.
What is the minimium of current that the sensor accept?
The min current is 1.5Amp and also make sure the CT is wrapped around only one wire.
Yes looks like Node-RED is working well, because you are receiving all data, as @Anil_Bhaskar mentioned make sure the CT is wrapped around only one wire, and is closed correctly:
If you have an Ammeter, you could check if the current value is between ranges of operation of sensor.
