Hi, I have a PR60-6_R220PL High-Power 2-Channel ProXR Lite with a PR55-22 WiFi Communications Module.
With 12V connected, the module stays solid green. Pressing R (briefly changes to half blue/purple led then back to green), tapping/holding C, power cycling, and trying USB connected/disconnected never produces flashing blue or the NCD_NexGen network.
Is this controller G2/power-compatible with PR55-22? Does it need a firmware update?
Press and hold the C button. While holding the C button press and release the R button. Wait for the LED to turn Blue, then release the C button. The LED should begin flashing blue.
did that, i hold down C, nothing happens, while still holding i press and release R, the light turns off then comes on half blue/purple, then a moment later goes back to solid green, then i release C and still shows solid green
