I have PR55-20A sensor, I want to monitor the temperature, vibration, and current of my machine.
However, the measuring spot distance between current and vibration is too long, so I can’t measure both at the same time.
Do you sell longer vibration or current probes? Or we can extend the current sensor or vibration sensor by ourselves?
Thank you!
You can extend the current probe but do NOT extend the vibration probe length.
Thanks for the reply.
I have a question that the current clamp is too small for our motor wire, can this clamp be changed?
what restriction we should notice?
Thanks!
The coil ration should be 2000/1.
we do stock some big one if you need.
