Regarding the PR54-3 board, the specifications and pinout sheet refer to Analog post A0-A5 being available. How are these addressed in Arduino code. Is there a special Library?
thanks
thanks
The pinout of that screw terminal interface board matches the pinout of Particle Gen 3 modules as shown here:
https://docs.particle.io/datasheets/wi-fi/argon-datasheet/#pinout-diagram
So if the Adafruit Feather is plugged into the PR54-3 the PR54-3 is not giving me any additional Analog ports other than A0 provided by the Feather. There is no additional ADC chip on the PR54-3? to provide A1-A5 for a Feather.
Is that correct?
