I received my order of contact closure modules (PR55-1A) with PR52-3B firmware.
When the counter threshold setting is met, it transmits the latest count as expected. However, when a transmission occurs due to the delay time, the count is not updated, it is the same value as the previous transmission. Therefore I only receives count values that are a multiple of the count threshold. Is this by design?
Yes, this is by design
Is there any way to disable the time delay transmission? Since this doesn’t provide an updated count value, it serves no purpose and is interfering with some calculations. I only need a transmission to occur when there is a change in counts.
Set the delay value to a really high value.
Ok…and what is the max value that can be set?
