PR49-24E Temp and Vibration sensor up and running with U900HP-S3BMSR_Zigmo modem. Results being read via Node Red. Originally thought I would measure machine pump or gearbox vibration with this device. When placed on a pump, a good pump, I am seeing values such as rms_X = ~1,000.
Are these readings in g’s?
Hi the readings are in milli-G or one thousandth of a unit of a G which I’m not sure what the abbreviation for that is (if there is one).
Thanks for your reply
