I’m struggling with the PR38 / PECMAC 6xxx we bought a couple of months back
When running the python script I found for PECmac125a (I couldn’t see any nodered nodes for this CT board which was the reason we bought them)
I have a 12v 1.5a powersuply to the board and have directly connected the IOT i2c board on the pecmac 6xxx to the SDA and SCL pins on the RPI3b+
The python script runs once and then after that we get no readings,
Distributed with a free-will license.
Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
PECMAC125A
This code is designed to work with the PECMAC125A_DLCT03C20 I2C Mini Module available from ControlEverything.com.
https://www.controleverything.com/content/Current?sku=PECMAC125A_DLCT03C20#tabs-0-product_tabset-2
import smbus
import time
Get I2C bus
bus = smbus.SMBus(1)
PECMAC125A address, 0x2A(42)
Command for reading device identification data
0x6A(106), 0x02(2), 0x00(0),0x00(0), 0x00(0) 0x00(0), 0xFE(254)
Header byte-2, command-2, byte 3, 4, 5 and 6 are reserved, checksum
command2 = [0x6A, 0x02, 0x00, 0x00, 0x00, 0x00, 0xFE]
bus.write_i2c_block_data(0x2A, 0x92, command2)
time.sleep(1)
Read data back from 0x55(85), 3 bytes
Type of Sensor, Maximum Current, No. of Channels
data = bus.read_i2c_block_data(0x2A, 0x55, 3)
Convert the data
typeOfSensor = data[0]
maxCurrent = data[1]
noOfChannel = data[2]
Output data to screen
print (“Type of Sensor : %d” %typeOfSensor)
print (“Maximum Current : %d A” %maxCurrent)
print (“No. of Channels : %d” %noOfChannel)
Command for reading current
0x6A(106), 0x01(1), 0x01(1),0x0C(12), 0x00(0), 0x00(0) 0x0A(10)
Header byte-2, command-1, start channel-1, stop channel-12, byte 5 and 6 reserved, checksum
command1 = [0x6A, 0x01, 0x01, 0x0C, 0x00, 0x00, 0x0A]
bus.write_i2c_block_data(0x2A, 0x92, command1)
time.sleep(0.5)
Read data back from 0x55(85), No. of Channels * 3 bytes
current MSB1, current MSB, current LSB
data1 = bus.read_i2c_block_data(0x2A, 0x55, noOfChannel*3)
Convert the data
for i in range(0, noOfChannel) :
msb1 = data1[i * 3]
msb = data1[1 + i * 3]
lsb = data1[2 + i * 3]
# Convert the data to ampere
current = (msb1 * 65536 + msb * 256 + lsb) / 1000.0
# Output data to screen
print ("Channel no : %d " %(i + 1))
print ("Current Value : %.3f A" %current)
Powering off the board and then back on gives another reading but the reading is out by quite a margin and not being able to loop the script makes the board pretty useless.
I know I must be doing something wrong , i2cdetect shows the board at 2a so I know it’s not a wiring issue
What am I doing wrong ?
