The product description states that the input voltage range for the board is 5V-32V DC.
I want to check this means the board can be powered by a supply ranging from 5V-32V?
Is this provided by either the screw terminal connector or barrel connector?
My confusion is that the drawing shows that these connectors accept +12V input. (Also the drawing has switched the connectors around).
