Noise
I’m using a pr16-4 relay board, Pr54-2 Featherlite IOT with Particle Photon2, Pr2-8 I/O.
I’m chasing a noise problem. With a standard volt meter, should I be able to measure pull-up voltage across the ground and input of the pr2-8 if my code is correct in activating the input pullup option? Thanks!
