I am using the PR55-61E vibration sensor model. I inquired about the battery consumption. I tried factory reset and pressed the RST button dozens of times. The battery lasts for a day and it says there is no battery. I am currently testing two sensors, and each one differs by about 0.06 per day. One unit disappears at a rate of 0.3 per day. Is there any other solution?
whats the firmware version?
do you have USB or ethernet modem ?
The firmware version is 11.
I am using a USB gateway and an Ethernet modem.
can you remove the radio module from the sensor and plug into the modem and use xctu to read its setting ?
If you connect the USB from the modem to the PC, you can load the radio module in xctu.
