Hello, I have a pH/temperature sensor that is reading 5-7 degrees C lower than three other sensors in the same pond. I have manually checked the temperature and the other sensors are accurate. I have tried removing the external temperature probe but this just further increased the error. Is there a command I can send to the sensor to calibrate the temp reading to a set value?
