pH Probe Calibration – Alpha Station Deprecated, Node-RED Alternative?
I’ve been calibrating the NCD wireless pH probe monthly for 3 years using Alpha Station with an NCD Wireless USB modem. Today the software stopped responding. I uninstalled it and tried to re-download, but got this error:
Cannot Start Application
Cannot download the application. The application is missing required files. Contact application vendor for assistance.
I also noticed the Alpha Station page now says it’s no longer maintained and to use Node-RED instead.
Can I calibrate the pH probe using Node-RED?
If not, how can I get a working version of Alpha Station to continue calibrations?
Thanks.
I found the solution. No need to reply. Thank you.
