I am using Alpha Station with a USB Modem to calibrate the sensor. The pH and ORP values seem to have both calibrated correctly, but the temperature remains off by 8 degrees C not matter the value or options selected for Temperature Compensation. The settings are stock with the warmup being 30 seconds and the delay remaining at 120 seconds. Any ideas on how get the temperature correct?
Yes, there are calib command for temp as well.
keep in mind the temp is installed inside the probe so if you put in any liquid it will take some time to come up to the real environment temp.
The sensor has been on for days at a stable temperature. The temperature should be 21 C but it is reading 13.6 to 13.8 C. I am trying to use Alpha station to adjust it but literally nothing I do makes any difference on the temperature. What am I missing?
can you share a screen shot of sensor readings?
it bit strange that both are reading somewhat close temp, i am assuming both are in same liquid.
what the temp if you put both in air ?
there was a command to offset the temp, we are looking in that.
are you using node red for logging the data?
Both probes are in my lab that is kept 20C and are continually reading in the range mentioned above. I have not been logging the data due to the temperature not reading correctly, but plan to use node-red when the data is accurate.
we sent couple of external temp probe just to make sure if the internal temp sensor is acting up. did you get chance to test it
When would those have been sent? I have not received anything other than my recent order.
Edit: I just received them from UPS. I will be traveling the next week or so and will send over an update when I have something available. How do you recommend I wire them in? Thanks!
We have tested the temp sensors on both the pH and ORP sensors and the temps remain consistent with the external temp sensors. We are also getting 25C with out the temp sensors or the probes connected. When I try to adjust the temp compensation and disable/enable I do not get any different results. What is the next step to getting this working correctly?
it will switch to 25C if the on board MCU is failing to talk to the temp sensor.
can you check and confirm its wired in and also share a picture of the pcb when you get a chance.
This makes sense, we were getting 25C when we had the temp sensors disconnected but with them connected we were getting values, just incorrect values. Room is around 70F and readings are around 58F Is there any way to confirm whether or not the temp compensation is being written? It seems the calibration is not working.
if the temp sensor is connected the compensation will work.
was the temp sensor connected during calibration ?
Yes the temp sensor was connected during calibration but after calibration and reset it didn’t change the values we were getting. We were using 20. We also tried to change the compensation with external temperature probes connected. Still didn’t seem to make a difference. Is the compensation calibrating the temperature or changing how pH and or ORP are measured?
I see, so as long as we adjust the compensation to reflect the appropriate pH and ORP readings we should be good even though the temperature readings are off? Is there a way to calibrate the temperature readings themselves?
