Has anyone ever connected a pH and/or conductivity meter to an NCD transmitter? I have a specific use case that requires pH in addition to temperature and level measurement.
HI,
whats the output of the p/h sensor.
generally its 4-20mA signal.
Yes, I’m trying to ensure that the electronic module for the pH sensor will output 4-20mA. What is challenging is finding one that is also battery powered. Mostly my question is to survey the community on what others have done to obtain pH measurements…
Hello, we are looking for the same use case.
Did you find a solution ??
Thanks.
we are working on releasing battery powered wireless pH,ORP,Conductivity and Dissolved Oxygen sensors. It should be available for purchase in next 4 weeks.
