I recently ordered the Particle Electron Ethernet overlay. I also tested it using the provided Ethernet library for Particle on your Github and everything is working great!
I would like to proceed with integrating this into a product I’m developing and had a question regarding the Ethernet library license. I see in the license file that you have released it under GPLv3, but in the library.properties file it states that the license is MIT. I checked the Arduino and Wiznet Ethernet libraries and saw that they are released under LGPL. Would it be possible to use your library under the terms of MIT or LGPL?
