I’m new, I have the High-Power Relay Controller 1-Channel + 8 Channel ADC ProXR Lite with RS232 interface.
I downloaded the library for this, does this get imported into the code in the background and you run commands from it? Lost.
This download contains a dll you can import into your projects. You can make calls to that library to operate the relay and read the A/D inputs:
https://media.ncd.io/20190207091118/BaseStationSource.zip
Thanks! I appreciate the info.
