Hello, I installed node-red. But, the ncd-red-wireless is not installed.
Under is my error in cmd.
gyp ERR! build error
gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe
failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Windows_NT 10.0.19042
gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
gyp ERR! cwd C:\Users\popo3.node-red\node_modules@serialport\bindings
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@2.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\popo3\AppData\Roaming\npm-cache_logs\2021-03-05T00_56_06_083Z-debug.log
4 Mar 18:56:06 - [warn] ------------------------------------------
4 Mar 18:56:06 - [error] Error: Install failed
