The sensor is trying to use a counter in node red.
If the signal remains the same for 6 minutes, the count remains zero
If there’s something wrong with the signal, I want to post it one by one
Is there a way?
I’m sorry, but I’m not sure I understand what you are trying to do. Can you please elaborate?
Okay. This problem has been solved Thank you for your reply
