No output value 4-20ma mirror pair, I see the correct ma signal inside config page
Hello, hopefully last question. My Mirror pair is working. I am sending 12ma on the transmit side and I see the 12ma on the receive side, but only inside the config web page. I see “Channel 1 output value” on the config page but it is zero.
I am using passive mode on the receive end (UP jumper not set), as my PLC input is loop powered.
I do see a signal on the PLC but it is only between “3200 - 4300” which equates to about 0-1ma in the PLC while I simulate 4-20ma.
Can anyone help? I have to leave the site today and if it doesn’t work I am in trouble. Thanks
