I have Node-RED connected to my Ethernet Modem, but I am not seeing anything from the sensor.
Fresh batteries are installed and the power switch is in the correct position. When I press the reset button the red light flickers, CFG also illuminates the light. I have tried the factory reset procedure countless times without success. (Should there be any feedback?) What other options do I have besides wiring up a cable to flash the board?
Good part of the day dear Dear NCD Team!. WE have the same problem with the sensor data as it happened with @deutschesedge . Could you help us? We really need your help.
