I would like to control a Pant Tilt system using the 8 channel keyfob.
Each button on the keyfob would put the Pan Tilt system in a different pre-programmed position.
Any help would be appreciated. I haven’t seen any motor controllers here. And I need encoders to know where the motors are at.
We do not have an off the shelf solution for that. However we may have the hardware you would need(application development/programming would be required). What type of output do the encoders on the Pan Tilt motors produce for position information?
