I got the a NCD1Relay + Particle and have been using the cloudcontrol code with some modification to the momentary part:
if(command.equalsIgnoreCase("momentary")){
relayController.turnOffRelay();
Particle.publish("Status", "OpeningFor10Min");
commandEntered = "OpeningFor10Min";
delay(600000);
relayController.turnOnRelay();
commandEntered = "ClosingAfter10Min";
Particle.publish("Status", "ClosingAfter10Min");
return 1;
This is not ideal as it causes the Photon go offline during this time. Is there a cleaner way to do this? I need it to turn off or on for 10 Minutes when a function is called. Any help greatly appreciated.
First thing I would try is something like this:
1- when the momentary command is received, you set a global flag
2- this flag is then catched by the loop() function and you delay(600000) there
3- I would make sure my firmware has this line:
SYSTEM_THREAD(ENABLED);
Second thing I would try (it builds on top of the first one):
I would change previous step 2 so instead of using a delay it would use a timer to turn off the relay.
This will guarantee the processor does not lose wifi connection I believe.
Good luck
Gustavo.
To add to Gustavo’s comments, a safer substitute to your Delay() is this line:
for (uint32_t ms = millis(); millis() - ms < 600000; Particle.process());
The Photon won’t do much else during the 10 minutes, but it will stay online and be able to process a “Stop” Function, etc, over the Cloud.
( +1 to using SYSTEM_THREAD(ENABLED); ).
OR:
If you ever want to turn the Relay ON for a given amount of time, You could also try the Momentary Class seen Here
relayController.momentaryRelay(1, RunTimeSecs*1000);
That would automatically turn ON the Relay for the selected RunTime with no delays required, (the opposite of your use-case)
I use this scenario a lot with the NCD relays:
// Pass RunTimeSecs through a Particle Function over the Cloud
relayController.turnOnRelay(1); // Relay ON
previousMillis = millis(); // previousMillis is a Global unsigned long
while ( (millis() - previousMillis) < ( (RunTimeSecs * 1000) - 2000) ) { // a "Safe Delay"
// This will Exit the While Loop() 2 seconds before the Pump Stops- so you can measure the pump's operating pressure, final Amps, etc
Particle.process();
// Measure Operating Pressure, etc, here- before turning the Relay OFF.
relayController.turnOffRelay(1); // Relay OFF
Thanks @rfontaine @gusgonnet this worked perfectly .
