I went thru the factory reset process, per Step 6 of https://ncd.io/lte-cellular-ethernet-wifi-iot-edge-computer/ . I can’t for the life of me get ncd-red-wireless to work in Node-Red, it just displays a red error triangle in the Palette manager and [object Object] in place of an error message. Removing and installing via command-line node_install.sh script ncd-red-wireless doesn’t help anything. Have also tried updating Node-Red and other components to later versions, but nothing has helped.
I also tried ncd-red-wireless-2, same thing… [object Object] error. Help getting at the real error here please?
This is after a fresh factory reset process with ethernet connected:
