We purchased a ProXR 2 Channel High Power Relay Controller with the Gen3 Ethernet Module for a prototype item. Unfortunately we were not aware that communications using the Gen3 Ethernet Module had to go through an Ethernet router rather than an Ethernet switch. The device we are building is designed to use a switch for various reasons and it can’t be changed at this time. We intend to use a static IP address and would not be using DHCP.
My hope is that there is some kind of work-around for our issue. So my question is just that. Is there a work-around?
