Good afternoon, I bought an MQ131 Ozone gas sensor module to get the Ozone level.
MQ131 Ozone Gas Sensor ADC121C 12-Bit ADC I²C Mini Module.
I want to know is there a way to change the load resistance of the MQ131 module so I can change the detection range and measure data from 0 ppb to 1000 ppb (basically I need the reading under 1 ppm).
If there is a method, how to change it properly.
Thanks in advance.
Regards.
