I like your products, but I have so many questions:
1.- Could I lost communication? If all the 5 module sensors have l2C pull-up resistors, the 5 resistors will be in parallel.
2.- All of these sensors, can be used in a Particle Boron device? (before I made the purchase) do you have the libraries?
a) https://store.ncd.io/product/sht30-humidity-and-temperature-sensor-±3-rh-±0-3c-i2c-mini-module/
b)https://store.ncd.io/product/css811-air-quality-sensor-i2c-mini-module/
c)https://store.ncd.io/product/mg-811-co2-gas-sensor-with-i2c-interface/
e)https://store.ncd.io/product/mq-7-carbon-monoxide-gas-sensor-adc121c-12-bit-adc-i2c-mini-modul
Can be used a sensor which one communicates via RX, TX , if I will be having 5 I2C sensors working togethers?
I will have also almost 3 analog sensors, what do you recommend us? Using directly to analog inputs or using Analog to Digital converter? We need accuracy and reliability .
We will be grateful if you help us answer these questions.!
