hi…!!
I have a WIRELESS ETHERNET MODEM (PR55-17B) and two TILT/INCLINATION SENSOR (PR52-33TS).
I need to connect these hardware with a Siemens PLC by MODBUS for an automatic control.
I can read these sensor from Alpha Station Software, but I need reading from my PLC.
I Configurate the ethernet port with a Static IP and activate the Modbus RTU option from the ConfigTool Software.
But when i scanning the Modbus net with the IP address, it´s not conecting.
Im trying with the remote IP Address with the remote port but neither
I need Modbus Information or how to read data sensors for my PLC information.
Additionally it looks like you’re using the static IP address jumper which is only recommended for initial configs. It should be removed after booting up the module to get the initial IP address.
