Mirx two way communication
Hello, we are looking to turn on remote pumps and communicate back that the pump has been energized.
if using mirx pair is it possible to close both closed contacts on the transmitter to signal one relay on the receiver to start the pump and the other to close the closed contact on the receiver signaling the transmitter’s relay to close starting the pump runtime monitoring?
thanks
shelly
Hi Shelly,
Yes, that should work.
