Currently I am prototyping the MirPro pair. Every component bar the current output of the MirPro receiver is working correctly. The receiver is connected to a test PLC to provide voltage to the output… In configuration mode the receiver current value is as expected on the configuration mode displaying the input from current source. no matter what the case is the output current will not align with the input value. Has anyone else encountered a similar issue?
Is there no output to the PLC at all or are the values simply incorrect?
there is no output to the PLC, thanks for responding!
wiring diagrams can be found under the drawings tab here:
If your PLC does not provide loop voltage for the signal you will want to wire in a power supply as shown in the bottom diagram.
