MirPro 4-20ma Receiver Firmware
Had an issue with a MirPro receiver, after unplugging it starting getting 2 red flashes. It was still receiving values from the sending unit, could see when connected in AP mode but had an error with the outputs. Decided to try re-flashing the firmware with utility found here: GitHub - telliottosceola/Flash_Script: Flash script for ESP32 based devices
I realized after flashing though that I had used the firmware for the sender, not the receiver. Firmware for the receiver doesn’t appear to be available in the python flashing script. Is there somewhere i can get the firmware to reflash this unit? Seemed like that would be the starting point although admittedly this may be a hardware issue.
Answered submitted support ticket.
