We have recently started using the MIRMR25 setup starting out with 1 sender board and 4 receivers with 2 relays on board…
we are getting ready to purchase the same as above but with 7 receivers with 2 relays on board.
they are using the XBPRO radios with the SMA antenna connectors on them.
my question finally is if a radio module goes out on the receiver board is it possible to just replace the XBPRO and update the sender board with the new radio mac address?
Allen
