What is the factory configuration that the XBee-PRO 900HP RF Modules are set to in Digi XCTU software?
I found this thread but it appears to be outdated information.
Thank you.
Thank you.
The baud rate needs to be set to 57600.
Destination High and Low need to be set to the address of the mating module. Destination High will always be 00:13:A2:00, Destination Low will be unique to the module. That address is printed on the bottom of the module.
All other factory settings may be left alone.
Let me know if you have any other questions.
What is the encryption key used?
if you are using with MIrC product then the encryption should be disabled and baudrate should be set to 57600
Encryption is enabled on the MirC product I purchased. Order #552196.
So I need to reconfigure the Xbees to non-encryption then?
can you share screenshot of all the module settings ?
leave all settings as it and set the baudrate to 115200 in both radio.
But what is the encryption key used?
key is 55AA55AA55AA55AA55AA55AA55AA55AA
