Hi
I am using the MIRCC1_serial controller to detect a contact closure on a momentary pushbutton. The device sends a notification when the pushbutton is pressed and also when it is released. I would like to configure the input so it only sends a notification when the pushbutton is pressed. The Push_Notification_Serial_Port_Quick_Start_Guide has instructions on how to do this using Base Station, but when I open Base Station and connect to the controller, the AD8 Relay Activator/Event Generator option does not appear. Is there another way to accomplish this?
