Does any one know if the message output by the MIRCC1 on contact closure can be custom programmed?
The Push notification boards have the ability to send 8 user defined bytes along with the rest of the packet.
They aren’t differentiated between open and closed states and its mixed in with the standard packet.
If that doesn’t suit the application and you have some knowledge with C or C++ development I might be able to recommend some hardware with the capability with a bit of development on your end using an Arduino.
