Hi all,
I have a sensor (a pyranometer) plugged into my MCP3428 (4 channels), itself linked to a raspberry pi. I tested with a multimeter, and the sensor does send current to the MCP3428.
Here is what I tried:
for all possible addresses for my device (it should be 0x68 but I try a range of 0 to 0x100 just in case), for all channels (1 to 4), I try to acquire the data using the SMBus.read_i2c_block_data function.
I read a solid zero in every configuration, even with addresses that are not my device’s (given that they don’t cause an InvalidArgument exception)
I did try to use the code found here GitHub - ncdcommunity/Raspberry_Pi_MCP3428_16Bit_4Channel_ADC_Python_library: MCP3428 16Bit 4Channel Analog To Digital Converter Interfacing with Raspberry Pi
but with no different results.
I tried another MCP3428 in case the hardware was faulty, but still no change. What could I possibly be forgetting/what could be broken without me knowing?
Thank you for your time!
ps: in case that helps, here is the code:
import SMBus
i2cbus = SMBus(1) # tried i2cdetect -y 1, the device is here
def get_adc(channel=1; rate=26, gain=2, adress=0x68): #this is the default adress in the doc
if channel == 0:
bitchannel = "00"
elif channel == 1:
bitchannel="01"
elif channel == 2:
bitchannel = "10"
elif channel == 3:
bitchannel = "11"
else:
bitchannel = "00"
if rate == 16:
bitrate="00"
base = 0b00000111
index = 0b00001000
total = 2047
# lets assume that rate is 16 and not do the other cases
if gain == 2:
bitgain="00"
cmd = "0" + bitchannel + "1" + bitrate + bitgain
result = i2cbus.read_i2c_block_data(adress, int(cmd, 2), 3)
print(result) # [0, 0, 0] every time
time.sleep(0.1)
data= i2cbus.read_i2c_blokc_data(adress, int(cmd, 2), 2)
print(data) # [0, 0] every time
for address in range(0, 0x100):
for channel in [1, 2, 3, 4]:
try:
get_current(channel=channel, address=address)
except:
print("This adress was invalid")
Here is my setup: (the cables are not very easy to show, sorry about that)
