I’ve connected the Arduino MKR 1400 GSM to the 4-Channel 4-20 mA Receiver (PR33-15) via I2C shied and ran the following example code from the MCP3428 Arduino library:
As soon as I upload the code, the boar disappears from the serial port. First of all, how can I reset the device to factory settings so I can start over? Second of all, what is going on with the code that causes this?
Edit: I connected a new Arduino board and then removed everything in the void loop section and replaced with serial.println(“We made it here.”); followed by delay(1000); The new board disappeared from the serial port same as above. This leads me to believe the library itself is causing this issue.
