Using this code:
All I did was change the print statements to python3 and wrapped it in a while 1: statement and added time.sleep(.3) at the top of the while.
Sensors plugged into channel 1 and 2. Thing is acting like its completely ignoring channel 2, 3, 4 and is spitting out whatever value is read on channel 1. Why? I am expecting to be able to read two sensors completely independently.
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# MCP3428
# This code is designed to work with the MCP3428_I2CADC I2C Mini Module available from ControlEverything.com.
# https://www.controleverything.com/content/Analog-Digital-Converters?sku=MCP3428_I2CADC#tabs-0-product_tabset-2
import smbus2 as smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
while 1:
time.sleep(.3)
# MCP3428 address, 0x68(104)
# Send configuration command
# 0x10(16) Continuous conversion mode, Channel-1, 12-bit Resolution
bus.write_byte(0x68, 0x10)
# Read data back from 0x00(0), 2 bytes
# raw_adc MSB, raw_adc LSB
data = bus.read_i2c_block_data(0x68, 0x00, 2)
# Convert the data to 12-bits
raw_adc = (data[0] & 0x0F) * 256 + data[1]
if raw_adc > 2047 :
raw_adc -= 4095
# Output data to screen
print ("Digital value of Analog Input on Channel-1: %d" %raw_adc)
# 0x30(48) Continuous conversion mode, Channel-2, 12-bit Resolution
bus.write_byte(0x68, 0x30)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-2: %d" %raw_adc)
# 0x50(80) Continuous conversion mode, Channel-3, 12-bit Resolution
bus.write_byte(0x68, 0x50)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-3: %d" %raw_adc)
# 0x70(112) Continuous conversion mode, Channel-4, 12-bit Resolution
bus.write_byte(0x68, 0x70)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-4: %d" %raw_adc)
Digital value of Analog Input on Channel-1: 494
Digital value of Analog Input on Channel-2: 494
Digital value of Analog Input on Channel-3: 494
Digital value of Analog Input on Channel-4: 494
