I have the 12 channel - 4-20mA board seen here
MCP3428 12-channel
I am trying to hook up a pressure sensor and an temperature sensor.
I have set it up in a loop circuit so that the positive line goes to the sensor,
the negative line from the sensor goes to the + terminal and the -Terminal goes back to ground
And I get nothing that looks like a proper reading. On the page for the device it states that the output for 4-20mA is supposed to be When resolution is set to 16bit
- at 4mA the raw ADC value will be around 5813
- at 20mA the raw ADC value will be around 29390.
I am getting ‘1’ back.
Am I missing something?
Any help is appreciated - thanks
Dave
Hi Dave,
Can you share a picture or your setup ?
also the code you are using ?
Code is from ControlEverything.com website with modifications to allow me to enter which channel I am on.
> #include <stdio.h>
> #include <stdlib.h>
> #include <linux/i2c-dev.h>
> #include <sys/ioctl.h>
> #include <fcntl.h>
> #include <string.h>
> void main(int argc, char * argv[])
> if (argc != 2)
> printf("Usage: mcp [channel]\n");
> exit(0);
> unsigned char chan = (unsigned char)atoi(argv[1]);
> // Create I2C bus
> int file;
> char *bus = "/dev/i2c-2";
> if((file = open(bus, O_RDWR)) < 0)
> printf("Failed to open the bus. \n");
> exit(1);
> // Get I2C device, MCP3428 I2C address is 0x68(104)
> ioctl(file, I2C_SLAVE, 0x6F);
> // Select configuration command(0x10)
> // Continuous conversion mode, Channel-1, 12-bit resolution
> char config[1] = {0};
> config[0] = ((chan & 0x03) << 5) + 0x09;
> printf ("Config byte is %d\n", config[0]);
> write(file, config, 1);
> sleep(1);
> // Read 2 bytes of data from register(0x00)
> // raw_adc msb, raw_adc lsb
> char data[3] = {0};
> if(read(file, data, 3) != 3)
> printf("Error : Input/Output error \n");
> else
> short raw_adc;
if (data[0] & 0x8000)
raw_adc = ((~data[0]) << 8) + ~(data[1]) + 1;
raw_adc = -raw_adc;
else
raw_adc = (data[0] << 8) + data[1];
> // Output data to screen
> printf("Digital value of Analog Input : %d config %d\n", raw_adc, data[2]);
The config value output (btye 3 returned from the read) matches the config byte sent in.
(Edit - fixed 2s complement conversion)
